Magnetic Diff
Postby MIKEEEE » Mon Dec 03, 2007 1:56 pm
Better late than never , only just seen this thread , without question the "EL" version of the Harm diff is leagues ahead of the standard version.
Not only does it work at any time and any conditions you can also tweek it to be bit more like a visco diff if you feel the need.
Having had almost all the diffs out there this one from Ian is the mutts n***s.
It´s not my job to fix everything, it's my job to get everything fixed!!
Postby R32GTR » Mon Mar 03, 2008 8:28 am
Hi guys, I have just picked up the conversion for my mag diff and I just have a question. It comes with two plates and 2 shims. Do the plates go up against the gear or the case? So does it go case-shim-plate-gear or case-plate-shim-gear?
Hope I didn't make it too confusing. :oops:
Thanks. :)
Postby regino » Thu May 20, 2010 3:37 pm
ian,as you see under your opinion Powerlock differential?
best regards
Users browsing this forum: No registered users and 7 guests
